help with xbox connections
Discussion in 'Xbox Forums' started by Stevie S, Nov 4, 2003.
  1. Stevie S
    Stevie S
    Getting an xbox for my son for his birthday this month, and I'm looking for a bit of advice on connections. I understand the box comes with an AV connector that has 3 phono outputs, which will plug neatly onto the sockets on the push-out flap of the Philips TV. However, I would also like an easy way to hook the box up to the plasma screen from time to time. Since my denon 3803 component inputs are taken up by DVD and sky+, I thought the next best option would be to have a lead connected to an s-video input and phono inputs (for audio signal) on the 3803, and have this dangling so the xbox can be plugged straight in when required.
    But how do you deal with the xbox end of things? I imagine you can't buy a lead that has an xbox plug on one end and s-video/phono on the other? Is there an easy solution?
    TIA
    Stevie
  2. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Stevie see here for a svideo lead for the xbox
  3. Stevie S
    Stevie S
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Stevie
    The one inzaman has linked to only provides s-video out through the scart connector. The one you found does indeed have a separate s-video connector. However, I would suggest one of the leads from Dixons or similar which has both a scart connector for RGB output and an S-Video connector. That way you can use the scart to give RGB quality to the tv and the s-video lead to feed to your 3803 when required.
    I think I paid about £15 for mine which is blue in colour. I think it is a Gamester or Joytech one but not 100% sure.
  5. Stevie S
    Stevie S
    That makes sense, Messiah. Will check this out later in the week. Still got a few weeks before his birthday to get it sorted
    thanks again
    Stevie
  6. Stevie S
    Stevie S
    One more thought - using a cable like this will only give me stereo through the 3803, is that right? Is there any way of having the xbox connected with s-video AND an optical lead for the audio, rather than the stereo phonos?
    Stevie
  7. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Stevie on the box that the leads go into there is a socket for an optical lead that can be used to feed into the amp. I know there is definitely one on the hidef pack and i am sure i have seen this input on the svideo leads in currys or dixons etc, but again probably messiah will be able to confirm. Sorry about the earlier error i though that was purely svideo, didnt really look at the picture.
  8. Stevie S
    Stevie S
    Thanks, Inzaman. Looks like a trip to currys is needed to sort out...
    best
    stevie
  9. Ten
    Ten
    Jul 1, 2001
    163
    16
    UK
