Help with wireless networking
Discussion in 'Xbox Forums' started by lewiszulu, Feb 7, 2009.
  1. lewiszulu
    lewiszulu
    Feb 7, 2009
    739
    Birmingham
    +23
    Ok, so i dont want to buy an official network adapter as it is so expensive.
    I was wondering what other alternatives i can use with my current set up.
    I have my PC connected wirelessley to a router and my xbox is next to my PC.
    It is not possible to run a CAT5 from the router to my PC.
    Any suggestions please?
  2. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    Edit - oh I see what you mean, run the connection off the wireless PC. I'm not sure about that sorry.
    I think it's possible but I also think it affects the connection speed.
  3. Gordon B
    Gordon B
    Dec 29, 2006
    6,084
    +1,054
    Wireless bridge which connects to the ethernet port of your 360 is one option.
    Or CAT5 from the 360 to your PC and use ICS. Means your PC will have to be on all the time you are gaming mind.
  4. astar0th
    astar0th
    Mar 12, 2008
    6,205
    Mojave Wasteland: Holding Kav's hand
    +1,243
    Hang around these forums long enough and you'll get an official jobbie for sub £39.
    It'll be you best and most solid connection.
  5. Delvey
    Delvey
    Jul 20, 2008
    9,305
    Manchester
    +2,932
