Help With What i need for a Panasonic TH-42PWD7
Discussion in 'Panasonic TVs Forum' started by stevier, Mar 20, 2005.
  1. stevier
    stevier
    Hi everyone, i don't know anything about plasmas but need help please.
    Firstly i've been offered a panasonic PH 42pwd from a private person for a £1,000, is this worth it??
    Also what components do i need to get it to run a PC with sound and also a sky box, it's for my new shop so any help would be greatly appreciated!
    I also need the cheapest place for these parts too please!
    Thanks in advance!
    Steve
  2. stevier
    stevier
    Isn't there anyone out there that can help me please?????
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    how old is the screen and do you know what inputs it has?........pc will go straight into the vga input...sky could go in via scart, s-video, js scart to component converter or via the pc if fitted with the right tv / capture card
  4. stevier
    stevier
    The screen is brand new and all it has is a vga input and thats it.
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    not sure what retail is / was for this screen but if it's brand new and from a reliable source it sounds good to me....what about warranty though? Also as it's for a shop and not home (therefore doesn't need to best or most elegant connection?) you could use a vga switcher...have pc and sky (via scart to vga converter) both plugged into vga switcher and vga switcher into screen.
    I expect you'll get more expert advice but its normally quiet at weekends.
  6. stevier
    stevier
    It's got the manufacturers warranty with it. is that 2 extra items i need then mep, 1: a vga switcher and 2: scart to vga converter and if so where can i get these items from please???
    Thanks for your help mep, much appreciated!!
    Steve
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Great screen, good price, you'll get it sorted no probs. Do you have speakers for it, or are you planning on separate sound?
  9. stevier
    stevier
    Maw, i don't have anything for it at the moment, it's just the bare screen thats become available to me, why does anyone on here sell good secondhand or not used parts for them?
  10. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There is a classified section here, good kit on there frequently. You will need a pair of stereo speakers, any budget hi fi ones will work. There are spring clips on each side of the screen, this will make some noise. The PC input has a 3,5mm stereo jack for audio. For a shop, I think I'd look out for a 2nd hand scart board rather than the vga switch, it will be easier for idiots to operate. The PC will need a VGA cable, and an audio cable with a 3.5mm jack on each end, sky connected with scart will carry audio as well. You will run into audio switching trouble with a VGA switch. Budget £60 or so for some decent speakers, 2nd hand or from Richer sounds, and say £75 for a scart board. You might like to upgrade later, but could easily connect a DVD to the 2nd sky scart and it will work. Make sure you enable RGB, and 16:9 in the sky services/picture menu.
  11. stevier
    stevier
    Thanks mate, will check it out!
    Regards
    Steve
