Help with Welltech Video Sender
Discussion in 'Home Cinema Control & Remote Controls' started by dudgeman, Oct 30, 2005.
  1. dudgeman
    dudgeman
    Oct 30, 2005
    7
    Hi, I've been using a Welltech AV sender for a couple of years now with great success. However, I've just moved house and the remote control feature no longer works, but the video is fine. Since it was a long time ago, I can't remember if I had to do something to 'tune' the remote control into the device. Any suggestions? It is really annoying not to have the use of the remote control upstairs!
  2. AGeddes
    AGeddes
    Feb 5, 2010
    3
    I need a s lead for my video sender as the rabbit has chewed through it it has a 6 point pin on one end and the 3 plugs yellow, white and red on the other end. Can you help?
  3. logiciel
    logiciel
    Feb 2, 2008
    53,170
    UK
    +5,792
    How did you find this ancient thread?! It shouldn't really be under Remote Controls.
    What is this "6 point pin" and what does it plug into? These usually have a Scart to 3 phono cable.
  4. AGeddes
    AGeddes
    Feb 5, 2010
    3
    I typed in Welltech Video sender and it came up with that. The lead is part of the video sender and has 3 jacks which plug into the scart which goes into the digibox. The other end goes into the sender and is a 6 point pin s cable I think?
  5. logiciel
    logiciel
    Feb 2, 2008
    53,170
    UK
    +5,792
    Well done the Search facility then - I didn't realise it was so efficient!
    So the receiver gets a Scart adapter with the 3 phonos, and at the other end of the cable there is what sounds like a s-video plug? That's odd though as they take only the video. Can you describe that plug more accurately?
  6. AGeddes
    AGeddes
    Feb 5, 2010
    3
    Sorted now I managed to get my mate to solder the 2 wires together.
    Thanks for your help!
