Help with voltage tv
Discussion in 'LCD & LED LCD TVs Forum' started by JaiMahadeshwar, Apr 5, 2017.
  1. JaiMahadeshwar
    JaiMahadeshwar
    Jan 2, 2017
    16
    London
    Hi I was just wondering if anybody could help.
    I have a UK Philips TV and a Philips tv from Germany. Is it possible to literally take the plug adapter cable from the UK one and put it into the German tv to power the German tv or will doing this blow it?
    Or do i need a European converter, I know Germany are on the same voltage as us and heard European converters dont change voltage just pin type when Europe to UK.
    Thanks for help
  2. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    Should be fine.
  3. JaiMahadeshwar
    JaiMahadeshwar
    Jan 2, 2017
    16
    London
    it worked thank you.
    it worked thank you
