help with viewing dvd from laptop to plasma
Discussion in 'Plasma TVs Forum' started by stevier, Apr 11, 2005.
  1. stevier
    stevier
    Hi everyone, this has probably been asked before, i'm trying to get my laptop pc to play dvd's to the plasma, have got the windows viewing perfectly but as soon as i play the dvds then i get nothing, Any thoughts on this???
    Have tried playing dvds through different dvd player software but no luck, any help on this would be most appreciated.
    Best Regards
    Steve
  2. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,268
    Are you using the plasma as your only display device?
    If you have cloned it from your laptop and have both displays running it could be doing full screen video on one display only... also what desktop resolution are you using?
  3. deanym
    deanym
    May 29, 2004
    1,833
    +143
