Hi All,
Ive had a good search around for help but I'm still a little unsure of the right path to take so I'm looking for some advice please.
I built myself a dedicated cinema room (approx 8m x 7m) and am looking to upgrade and improve the audio side
The AV kit was put together on a budget and a mish mash of kit I already had which consists of a Denon AVR-x2400 receiver, kef Q fronts, a boston centre and mission surrounds (with a BK monolith sub). I'm running 7.1 currently .
I'm having to run the amp volume pretty hard to get reasonable volume and I'm sure that not right? (80 - 85 on the display depending upon source)
I also want to go to 7.1.4 in the near future.
I've been looking at Denon AVC-6700 and 8500 but have been investigating something like a denon 3700 coupled with a 3 channel power amp (Emotiva 3 channel for LCR or similar and let the AVC control everything else)
I plan to upgrade my LCR very soon to but I'm interested in the path. 90% movies and 10% music.
Would appreciate your insight into my path and options (amp or speakers first upgrade and amp choice?) Part of my problem is that I'm not sure what impact of amp upgrade will have on my current setup. If I go to a avc-x6700 will I get substantially higher sound levels? Power comparisons in specs seem to be a numbers game from what I read, and I'm worried that I'm going to be disappointed after spending £1500+ on an amp!
Thanks in advance
Thanks in advance
