Help with unknown AV cable
Discussion in 'Cables & Switches' started by davidgt1973, May 12, 2005.
  1. davidgt1973
    davidgt1973
    I have recently purchased a high spec satellite receiver that does not have standard outputs for audio or video.The video output requires a bnc connector however the audio output is via a 9 way,d-type male connector ( i require the female)that has the following connections:
    Pin 1 Digital audio +
    Pin 2 Ground
    Pin 3 Left +
    Pin 4 Right +
    Pin 5 Ground
    Pin 6 Digital audio -
    Pin 7 Ground
    Pin 8 Left -
    Pin 9 Right -
    Having contacted the company where i purchased the receiver i believe i need to start with scart breakout input lead but dont know where to go from here or if i actually need something manufatured for me.
    If anyone could steer me in the right direction i would be most grateful.
    David
