Keithjones
Hi - I am looking for some advice and help with the installation of a smart light switch.
Firstly I would like some help in understanding the wiring set up I have on the switch to replace.
I live in a new house so I expected the wiring to be good and easy to follow but....
In the pictures you can see its a simple on/off switch to one light, there is one live wire to com and 2 live wires to L1. Neutral wires are joined in a block.
Q1: What sort of smart switch do I need? With or without netrual?
Q2: How do I then wire it to the new smart swicth?
Any advice and help would be really appreciated
Keith
Keith
