Question Help with TV voltage
Discussion in 'General TV Discussions Forum' started by Vidura1995, Mar 13, 2017.
  1. Vidura1995
    Vidura1995
    Mar 13, 2017
    7
    4
    Manchester England
    I got this LG OLED coming in from the US and the website indicates that it runs on 120VAC 50-60hz but unfortunately our supply is running at 240V. I brought down one of these voltage converters - Diamond Series with Regulator - BEST - Voltage Converters and it converts from 240 to 110V. would the 10V difference be any issue ?
    thanks!
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,279
    Manchester
    +762
    I would be most surprised if the missing 10 volts made any difference.
  3. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,263
    Poole
    +9,562
    You could have a bigger problem than that - US TVs aren't designed to display 25/50fps video.
    North America uses 60/60fps video.
    Blu ray will be OK, 24fps for all regions.
  4. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Of course it won't have a Freeview HD tuner either but that will not be important if you are sourcing your signal from elsewhere.
  5. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,263
    Poole
    +9,562
    No, the EDID won't list 25/50Hz modes either, I have had this before and in the US/Canada there are shops that sell European import TVs for this reason.
    There is an ex-pat market.
