Help with TV/DVD connections Please
Discussion in 'Plasma TVs Forum' started by Plasmoo, Sep 3, 2007.
  1. Plasmoo
    Plasmoo
    Aug 29, 2007
    38
    11
    +4
    I hope that you can talk me through the cable connections between my new gear so I will tell you what I have & perhaps you can list what I need to do in simple terms as I'm new to Plasma TV's etc.
    I am setting up the items below
    Samsung DVD recorder (DVD-R155)
    Samsung PS42Q97HDX Plasma TV
    Virgin V+ sat box
    I have connected my DVD & Virgin box, using Scart's, to my CRTV already as I'm waiting for my Plasma but have some questions about connecting to the TV when it comes.
    I connect the HDMi from the V box to the TV
    I connect the HDMi from the DVD recorder to the TV
    Do I still need to run a Scart from the V box out into the DVD in connection to be able to record from V box to the DVD ? or will the two HDMi's into the TV from the DVD & V box allow this.
    Sorry to list it all like that but unless I do I just get confused :)
    You help will be greatly appreciated
  2. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    I believe HDMI is pretty much a one way street so you'll need a separate SCART connection between the V+ box and the DVDR
    and no problem on the list, makes everything clear :)
