Right, I need some help with speaker placement for my first surround sound set up. I've spent too much time on trains recently and put together a SketchUp model. There are a couple of screenshots below.
Front speakers
If I put them on the shelves they will be behind the screen and centre speaker, will that sound bad? Should I bring them forward a bit on stands?
Rear speakers
The sofa fits neatly into the bay window and I see a couple of options of rear placement:
1 = Green speakers in picture
The speakers are behind the sofa, quite close together (1.5m) and close to the main seating position (<1m).
2 = Red speakers in picture
The speakers are out wide but in front of the seating position (just out of eye line) and one will be right in front of a radiator.
Neither is ideal but which will sound better?
As you can probably tell I've been thinking about this for a while but really need some expert help please.
So far I have picked up an Onkyo 805 that I have since found is too big for the furniture we have chosen which is why the hardware is probably going to live on custom build shelves to the right of the TV
. Speakers are probably going to be KEF 3005s or B&W M1s because their looks have been passed by my wife! Main bit of room (excluding bay window) is just under 4m square.
Front speakers
Rear speakers
