Help with TomTom6 + Solar Bluetooth GPS receiver
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by junior78, Sep 18, 2007.
  1. junior78
    junior78
    I have got a XDA exec with Tomtom6 and a Solar Bluetooth GPS receiver...I am able to pair the device with my PDA and am also able to configure and define incoming and outgoing ports...COM 8 for incoming and COM 4 for outgoing....when I try and go to my tomtom software the only option which I get is to select the GPS type, in order to configure the device....and after selecting it keeps connecting to GPS device and nothing happens....I have even tried with Incoming (COM4) and Outgoing (COM8) and even with COM0 settings for COM ports within XDA, but to my bad luck I am not able to connect to the GPS device....can someone kindly help me with the above please
  2. droopsnoot
    droopsnoot
    Feb 15, 2007
    68
    11
    +4
    As I recall it, you need to set the TomTom to use "other wired GPS receiver", set it to use the outgoing COM port, and that should be it.
  3. rickyt
    rickyt
    Jan 7, 2005
    1,058
    63
    Northumberland
    +137
    I just got my new 44 channel Holox gps BT reciever on Saturday and configured it to my Ubiquio running TT6 .Paired them together , input port , outgoing port & configured the settings within TT for the BT device and boud speed .It only took a few minutes .As long as your paired up with the BT ,you should alter the settings from within TT as droopsnoot has suggested.
  4. Autopilot
    Autopilot
    Feb 5, 2005
    7,630
    Region 2
    +1,517
    On the XDA i believe you need to configure the bluetooth GPS unit to a serial port.
    Otherwise, I'm sure TomTom helpdesk will be pleased to help.
    Polite mod notice; I have deleted the duplicate thread in Mobiles/PDAs - don't cross-forum post please.
