B1llyCh4Cha
Some help pls from you knowledgeable chaps re throw distances.
Preliminary pics of my screen attached – screen will come down lower once I’ve adjusted the blackdrop. Room will be off white - in the interests of domestic harmony, I won’t be trying to recreate a dark room. Used for evening movies only.
The 110” Stewart Firehawk tab’ed screen looks a little small in the area where it is fitted and just need to know if I am able to fit a wider screen, and if so what size and which ones are currently recommended.
Measurements in mm are:
Void: Viewable area W3300 H2209H D838
Beam: H279
Max distance screen to PJ lens: 4m
The area will accommodate a 120” screen (I have more width in the void, so can accommodate a wider screen bracket). Problem I have is throw. PJ is an Epson 9400. I’ve tried to make sense of the various throw calculators without success. Am I right in thinking I can go 120”, but will need to use the zoom function? If so, will I be sacrificing much by way of image quality by doing so?
Any recommendations on electric screens? I’ll need a black drop to clear the beam.
thanks
Beam: H279
thanks
