Help with TH-42PWD7BK
Discussion in 'Plasma TVs Forum' started by ollysteve, Jun 17, 2005.
  1. ollysteve
    ollysteve
    Nov 26, 2004
    95
    Cumbernauld
    I have a TH-42PWD7BK and I have noticed a noisy picture when watching DVD's via my Toshiba SD240E. It is wired up via component using Van damme cables. Is this normal or could I do something to improve the situation. I run a sky+ box via js scart to VGA and notice the same problems. It looks like thousands of tiny coloured dots when you get up close to the screen. Any help would be appreciated. More noticeable when there are dark scenes especially blacks.
    Steve
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,458
    WEST MIDLANDS
    +1,412
    What you`ve described is normal when you have the brightness and contrast set too high and stand close to the screen.
    Try lowering the settings slightly and you should see an improvement.
  3. ollysteve
    ollysteve
    Nov 26, 2004
    95
    Cumbernauld
    Thanks Carlos, I will try later and let you know the results
