Help with Tannoy Speakers
Discussion in 'Home Cinema Speakers' started by F G Evans, Jan 13, 2005.
  1. F G Evans
    F G Evans
    I am in the process of setting up the sub woofer i had with my Tannoy 5.1 fx speaker set.
    It states to connect the subwoofer with a RCA cable to either the left (red input ) or the right (white input).
    Am i right in thinking that a RCA cable is just a normal audio red & white cable ie one which is used to connect a dvd players audio or Tv audion to an amplifier or is it different.
    Also soes it make a difference as to whether i use the left or right connection.
    Also what benefits does connecting in this manner have over connecting by ordinary speaker cable (which is also an option with this subwoofer).
  2. F G Evans
    F G Evans
    anyone?
  3. Andy Dee
    Andy Dee
    Sep 1, 2002
    197
    +3
    You can use a standard RCA cable. There are the usual pro-cables (inc Designed specifically for subwoofer) but a good RCA cable will do.
    Not sure of the advantages of a good RCA against a good length of speaker cable....Less chance of shorting (practical advantage)
    I think the reason you can use left or right is because the very low frequencies are non directional -ie both channels are fed much the same signal. I think Left is the default if possible.
    Please correct me if i'm wrong.
