help with tannoy efx5.1 setup
Discussion in 'Home Cinema Speakers' started by nisnos, Nov 7, 2005.
  1. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    hi
    i have a yamaha rxsl80s AV reciever and amp and the aforementioned speakers
    i read this
    "The subwoofer module unboxed easily enough. It does not feature a variable crossover, so don't bother looking for one! This sub is matched to the Tannoy system and is meant to pick up frequencies below 140Hz, where I'd recommend you set the receiver crossover if possible. One thing to note, if you have a Yamaha receiver, notorious for its fixed 90 Hz bass management crossover, you'll find that much of the sound between 90 and 140 Hz may be taking a vacation from your system. To get around this, you may want to set your main speakers to 'large' and use the speaker level inputs of the subwoofer to provide the appropriate cross-over for the subwoofer"
    how do i do this or does anyone have a good setup.
    many thanks
    dave
  2. swartzy
    swartzy
    Apr 16, 2001
    9,635
    Northern Ireland
    +725
    Hi nisnos,
    to set your main speakers to large you normally have to access via your setup menu on your yamaha remote (check your manual) when you press the menu button you have a series of options shown up either on your front display of the amp or on-screen depending on whether you have this option.....Normally to set speakers to large you have to go into a menu called Speaker Set then goto Front then press on enter button on remote and you will see this changing from SMALL---LARGE----NONE set it at large then press the arrow keys to get you back out of the menu....
    (I am going with my experience of my Yamaha AX2 amp as most Yamha amps are similar) if in doubt check the procedure in your manual as to speaker settings....
    The speaker level inputs on the sub just simply means the red and black connectors on the sub similar to your other speakers in your set up.....Follow the instructions on your subwoofer manual to run speaker wire from your sub to your front two speakers....
    Hoping I haven't confused you totally....lmk how you get on
    Regards
    swartzy
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    1. Run your left and right speaker outputs from the amp to the inputs on the sub.
    2. Run the the outputs of the sub to your left and right speakers.
    3. Set the left and right speakers to large in the amp setup.
    4. Tell the amp there is no sub.
    5. There may be an option to 'direct LFE to the front left and right'. Take this option if available.
    The same as above essentially but a little simpler to comprehend...
  4. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    many thanks ill do that tonight
  5. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    right ive done that but i have the option to adjust the crossover frequency from 40hz to 200hz along with the phase of the subwoofer
    is there anything here for me to adjust please.
    thanks
  6. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    oh also how about the LFE level setting? -20db to 0 db
    sorry for being a bit numb but its all quite new to me.
  7. swartzy
    swartzy
    Apr 16, 2001
    9,635
    Northern Ireland
    +725
    Hi nisnos,
    I have LFE settings set to -6db and crossover frequency at 80 hz
    swartzy :thumbsup:
  8. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    hi swartzy
    i have 2 settings for the LFE SP and HP which one should i fiddle with
    thanks so far
    nisnos
  9. swartzy
    swartzy
    Apr 16, 2001
    9,635
    Northern Ireland
    +725
    think the SP is for the speakers so try and change that......HP is for Headphones
  10. nisnos
    nisnos
    Sep 29, 2005
    2,161
    manchester
    +69
    er
    DOH!!!!!!!!!!!!
    Sorry for that its been a long night.
    thanks for all your help
    dave
  11. swartzy
    swartzy
    Apr 16, 2001
    9,635
    Northern Ireland
    +725
    no worries Dave.......hope you enjoy your new amp and speakers
    Good Luck
    swartzy :)
