Help with SVSubwoofer
Discussion in 'TAG McLaren Audio Owners' Forum' started by Spudzz, Dec 20, 2004.
  1. Spudzz
    Spudzz
    Aug 4, 2004
    188
    Cork/ Munster
    +6
    Just purchased a SVSubwoofer and would like some advice on intergrating this sub into my system,which consists of an AV32R/DP + Tag CDT + Rotel power amps + Sony DVD Player + Castle Harlech speakers.
    This is the first time I have used a sub so any help would be much appreciated. :blush:
    Merry Christmas to you all
    Spuddz.
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Set the cross over where your full range speakers run out of low end, TMREQ it and set the levels with your meter. Job done :thumbsup: I have mine tuned for 25hz with no port plugs as I find it gos plenty low enough :devil:
  3. Bogi
    Bogi
    Oct 12, 2003
    403
    28
    Sweden
    +27
    I have my SVS 25-31pc+ set to 20Hz and it digs deep down under that freq :clap:
    Set the SVS cross over to off and let the AV32DP take care of the Cross Over. TMREQ and sit back and enjoy... :D
