invisible_kid
i was wondering if you connect say a 360 and hd sat box via hdmi to your tv then optical from your tv to your receiver would that give you surround sound on both the 360 and hd sat box. i say this cause i have 1 optical input on my surround sound. i know you always try to plug the optical cable directly from source to receiver but does this give you any benefits if what i say above works,
i take it my other option is a toslink splitter
thanks for help
thanks for help
