Help with "stylish" powered speakers for Keyboard
brotchaq
Hi all
I've a Roland RD170 stage piano in the dining room. It has no internal speakers so I need something to hear it with!
I've been allocated a shelf to put the speakers on but having an amp as well is out of the question.
I'd like a good sound from the speakers but since they are fed from a keyboard, the speakers need to be powered.
Also, I dont want two black boxes on the shelf (and neither does the wife).
Headphones aren't an option.
So, anyone suggest a good set of powered speakers that also look a it stylish?
Budget is a tight £150 - which will probably have a large bearing on things .:thumbsdow
Thanks in advance for any advice etc.
rgvsean
Not sure how loud you want to go but Harmon Kardon Sound Sticks (£100) look and sound great. Have used them on PC but my daughter now uses them for Blu ray and PS3 in her room.
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
