help with speaker setup
Discussion in 'Home Cinema Speakers' started by scudo, Jan 31, 2009.
  1. scudo
    scudo
    Jan 31, 2009
    3
    +3
    I wonder if anyone can help :
    my friend owns a restaurant has been left high and dry by an av company who went bust in the middle of a job and he has no money to pay anyone else.
    There are 8 JBL ceiling speakers fitted plastered in and cables running to behind bar area, they have used regular 42 strand speaker cable for each speaker . The speakers are 8 ohm 80w rated. luckily they left the amp a Teac AR610 with 130w per ch output at 8ohm or 100w per ch at 4 ohm.
    each speaker is in a different section of the restaurant so Ideally i'd like to run them in mono so that theres no sound separation in that area.
    Can I bridge the output from the AR610 to mono at the amp and connect amp to some sort of connector then each speaker to that connector.?
    also can I put an in line volume control to each speaker?
    obviously I'm concered with potential impedence problemd and damage to amp etc
    Any help would be appreciated.
    Thanks!:thumbsup:
  2. ResidentDeagle
    ResidentDeagle
    Dec 18, 2008
    1,838
    Nottingham
    +62
    get a AA battery, and connect the + to the + and - to the - and you should here like a cracle from the speaker, thus you can find the position of the speaker and connect them to the amp.
    hope that helps mate.
    just read it properly your question :S
  3. scudo
    scudo
    Jan 31, 2009
    3
    +3
