Help with speaker setup FS2AV + Denon 3802 +MS25i's
Discussion in 'Home Cinema Speakers' started by Pigwhistler, May 1, 2002.
  1. Pigwhistler
    Pigwhistler
    May 1, 2002
    220
    Goole
    +9
    I've recently purchased a Denon 3802 amp and the Mission FS2AV speaker set (not yet delivered). Obviously I want to be able to use the extra speaker channels on the Denon but i'm a bit suspect about buying a 2nd set of FS2's to act as the extra surround channels.
    I do have a pair of Mordaunt Short MS25i's which to my untrained ear sound quite decent, and up until my foray into the AV market, were very serviceable as speakers for my old 4:3 28" tv (soon to be replaced with a 32" Tosh W/S tv).
    Question is - can I use the MS25i's as front speakers still, and then move the fs2av front speakers to function as the surround ones without making a muddle of the sound? I obviously wont be using the umbilical and included speaker cable if I do this.
    Warren
  2. garliadr
    garliadr
    Feb 25, 2001
    817
    28
    +27
    I contacted Mission by e-mail yesyerday with the same sort of query. I wanted to use my existing FS2-AV centre speaker as my rear centre and purchase a mission m7c? centre speaker for use as my new centre. This is the reply I received,
    Dear Sir,
    Thank you for your e-mail.
    With regards to your question, the Mission fs-2 is designed for where discreet, elegant audio visual system is required. The fs-2 offers state-of-the-art sound derived from the nxt surface sound technology. The fs-2 package sound best where all the speakers are matching (ie. using flat panel speakers throughout and not mixing with pistonic speaker). I suggest that you audition these systems and then you will be able to determine the differences.
    <<DOLBY EX.pdf>>
    Further information on Mission products is available on the following web page: www. mission.co.uk
    I hope this information is of help.
    Kind regards
    P. Balmi
    Mission Info.
    So maybe it could be done, I don`t know. Anyone else out there using their FS2-AV with other speakers!
  3. Pigwhistler
    Pigwhistler
    May 1, 2002
    220
    Goole
    +9
    Well i was thinking, I can but try it and see what its like. If it doesnt work I can get another pair of fs2s and a sub as mission suggests, but if it sounds ok to me then I've saved that extra cash.
    warren
  4. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    pigwhistler, this has already been discussed a few times.. (search for fs2 + 6.1)
    the mission dolby ex pdf file mentioned has the answer and fully discusses the solutions.. (see below)
    http://www.staff.livjm.ac.uk/cismconn/fs2av-EX-ES.pdf
    basically you dont want to do it with your old speakers mentioned - they will not match sound-wise...
    you can either go for a stereo fs2 pack (including another sub).,
    or the far cheaper route, a pair of Mission bipole ds series.
    you can pick these up from Richer for about £100.
