Help with speaker settings LARGE or SMALL
Discussion in 'Home Cinema Speakers' started by THE-STIG-08, Feb 4, 2009.
  1. THE-STIG-08
    THE-STIG-08
    Nov 1, 2008
    151
    maidstone
    +11
    Hi, i know this has probably been asked a hundred times but i need some advise on the speaker settings on my B&W 603 S3'S and my REL 305, i currently have my speakers set to small in the main configuration and the sub set to yes, the LFE or LFE/MAINS is set to LFE and the crossover is set to 80, in the stereo configuration i have the speakers set to large with no sub, when it was installed the guys who installed it set the fronts to large but my daughter got her hands on it and managed to change every setting known to man:mad:, i phoned the store and a different instalation team set it up completly the opposite and now im not sure which setting is correct, can anyone give me some advise on how they would set up the equiptment shown in my signiture?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    That's how I would have set it up if it were mine
  3. THE-STIG-08
    THE-STIG-08
    Nov 1, 2008
    151
    maidstone
    +11
    excellent! thanks for your advise ian
  4. jukemark
    jukemark
    Sep 26, 2005
    208
    The New Forest/South Coast
    +5
    You should set the 603's to Large with the Sub crossing over at 60hz. The 603"s have no problem with low Bass and dont need to be protected, in fact you will be holding them back and taking away all their dynamics! Give it a try :thumbsup:
  5. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    Read here ,
    Set Your Speakers to Small in Your Receiver Setup
    Set to Large , any crossover setting is usually ignored and everything goes to what should be a set of full range speakers.
    The Sub is not used in this case.
    If you want to make use of the Sub , always set to small with a crossover.
  6. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Yes, that will work nicely with the limitless power reserves of a 2809.:rolleyes:
    Russell
  7. jukemark
    jukemark
    Sep 26, 2005
    208
    +5
    You can set the Sub to work WITH full range speakers on any Denon Amp.
  8. THE-STIG-08
    THE-STIG-08
    Nov 1, 2008
    151
    maidstone
    +11
    cheers guys, i must admit when the speakers were set to small it seemed like it had reduced the dynamics, i will try them out on the LARGE setting. :thumbsup:
  9. THE-STIG-08
    THE-STIG-08
    Nov 1, 2008
    151
    maidstone
    +11
    once again thanks for all your comments, i have set the speakers to large and lowered the crossover to 60 and it sounds fantastic now, it seems to have a lot more dynamics than it previously had when the speakers were set to small. :thumbsup:
  10. deckingman
    deckingman
    Mar 23, 2008
    1,812
    83
    +263
    Russell. That'll teach you not to be sarcastic :D.
