seismicsurfer
Hi All,
I hope someone can help with a speaker and amp configuration.
Equipment:
Roksan Kandy K2 integrated amp
Audiolab 8000CDQ preamp
Audiolab 8000P poweramp
Speakers B&W CM6 S2
Speakers B&W CM8
Subwoofer B&W ASW610
Thorens record deck.
1.Can I connect the Roksan as an output only to the Audiolab in order to use it as a phono stage only for the Thorens? I like the sound.
2. Can I run the CM6, CM8 and the sub together on the Audiolab power and preamp?
The objective is to combine both systems and run everything together. It might sound bad but I would like to try.
The alternative is to run both systems separately. Roksan for analogue and the Audiolab for all digital stuff.
If I do that, can the sub be shared between the two systems?
My primary source of music is vinyl.
I hope this makes sense to any of you wonderful people out there.
Thanks for your help!
Karl
Equipment:
Speakers B&W CM6 S2
Speakers B&W CM8
Karl
