Help with soundcards
Discussion in 'Computer Components' started by Moby Nick, Oct 7, 2004.
  1. Moby Nick
    Moby Nick
    Hi folks - just found these forums and hope someone can help.
    I'm looking to build my first HCPC and am fairly set on most of the components I intend to use apart from the soundcard.
    I'm looking at the Soundblaster Audigy ZS and the Audiotrak Prodigy cards (or are there other alternatives I have overlooked?). I want a good allrounder - good for music/DVD/HDTV and games.
    I have a couple of questions:
    1. If I connect the Soundblaster via SPDIF to my DAC, does this get around the 48Khz resampling issue (and would the sound quality therefore be improved?)
    2. Which connection/s do I use on the soundcard for 5.1 sound for games?
    Any help greatly appreciated.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Sorry, can't help you with the sampling question, it's not something I bother about.
    I have an Audigy 1 for gaming which feeds a Logitch Z680 sound system so I use the SPD/IF when playing DVDs to use the Z680's DD/DTS decoder. When gaming I use the 3 analog outputs to feed 5.1 into the Z680. In both cases the Z680 is 'playing' at being an a/v receiver.
    Not sure if this is what you're getting at or not. :)
