Help with sound.
Discussion in 'Home Cinema Buying & Building' started by hilts10, Feb 9, 2014.
  1. hilts10
    hilts10
    May 7, 2010
    41
    11
    Blackburn
    Hi all. I have just bought a Denon AVR X2000 paired with Wharfedale DX1 speakers and am very happy with their performance from a budget system. I have a Samsung UE50F6500 TV , I am connecting the tv to the Denon via HDMI ARC . The sound when using sky is fine and comes out of the speakers but when I use the smart features on TV like YouTube ,spotify or viewing home video from NAS drive I can only hear the sound when using the tv speakers and not the surround speakers . I have messed with settings but can't find a solution . I'm sure it's a simple fix and I'm sure that the experts on here have it.
    Thanks in advance.
  2. Rottie
    Rottie
    May 1, 2007
    925
    46
    +135
    Hi there,
    This is just a shot in the dark guess, but have you tried using a seperate optical cable to carry the TV's audio out to the AVR?
  3. hilts10
    hilts10
    May 7, 2010
    41
    11
    Blackburn
    Yeh I have an optical cable from my TV to the optical in for TV on AVR.
    Cheers.
  4. moonmonkey666
    moonmonkey666
    Feb 10, 2014
    So silly Q but did that sort it then, please mate? It's just I have exactly the same problem when using BBC iPlayer, YouTube etc from the "smarthub" on my Samsung!!
  5. hilts10
    hilts10
    May 7, 2010
    41
    11
    Blackburn
    No it didn't sort it. Can still only get sound through the TV speakers when viewing youtube, iplayer etc. I've Google it but I can't find a solution. Starting to get annoying now.
  6. Rottie
    Rottie
    May 1, 2007
    925
    46
    +135
    Hi again,
    Sorry you couldn't find a resolution by googling, but what I would strongly advise you to do is give Samsung's CS a call and ask for their "solution".
    Contact details are as follows (as per their website)
    • OPENING HOURS
      • Monday - Saturday | 9am to 6pm
      • Bank Holidays | 10am to 4pm
      CUSTOMER SUPPORT CENTRE
      UNITED KINGDOM
      • 0330 SAMSUNG (7267864)
        0330 numbers are included in your free usage if eligible or cost the same as calling a landline
  7. hilts10
    hilts10
    May 7, 2010
    41
    11
    Blackburn
    Yee Ha I've sussed it.
    I had to change the settings on the AVR. I have the HDMI cable connected from the ARC HDMI from TV to the ARC HDMI on the AVR (no need for optical) then changed the HDMI setup on the AVR set to HDMI control on. That sorted it out and now when I watch iplayer, YouTube, Netflix etc the sound comes out of my surround speakers, although only stereo, unless there is a 5.1 film on Netflix.
    Thanks for all the help and hopefully this can help others.
  8. Rottie
    Rottie
    May 1, 2007
    925
    46
    +135
    Glad you got it sorted. :thumbsup:
  9. Ankur Periwal
    Ankur Periwal
    Feb 14, 2014
    22
    Hi everybody.
    My media room size roughly is 16×22(ft). I already have an 3d projector and want to buy a new home theatre system with a separate AVR. After lot of deliberations have zeroed in on denonX500 with wharedale DX1 HCP because of budget constraints but can push the budget a notch up if there is anything better than this combination. So do suggest and your prompt reply will be very helpful. Thank you
  10. dante01
    dante01
    Mar 5, 2009
    46,086
    +11,044
    This board's membership is primarily made up of members located in the UK so it is hard for them to relate to your budget or make suggestions as to what it will afford you in the USA?
    I would seriously suggest you look at larger speakers for a room of that size. I'd also suggest you look a little higher in terms of what is to power them. If you can't afford to do this now then wait unitil you can afford to do it.
  11. Ankur Periwal
    Ankur Periwal
    Feb 14, 2014
    22
    T
    Thanks for the input........actually the budget is approx.1500 USD.
    What should be the all9cation for both the things i.e.Inbetween AVR and Speaker system. Which company's system do you recommend.
  12. Ankur Periwal
    Ankur Periwal
    Feb 14, 2014
    22
    Is this much budget sufficient for the room's size, i hope so that it suffices and what brand should i go for??
  13. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,723
    The Borders
    +3,513
    Your budget looks fine - though you can always spend more with this hobby.
    Where about are you and do you have local specialist Retailers you can visit to demo/purchase a system.
    Joe
  14. Ankur Periwal
    Ankur Periwal
    Feb 14, 2014
    22
    I am in India. My residence is app.250kms away from delhi and at my place there are not too many local retailers for hi fi sounds. Guess i will have to go to delhi for a live experience for these systems. As far as you are concerned what should be the ideal choice.
    Highly appreciate your response.
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,723
    The Borders
    +3,513
    ‘As far as you are concerned what should be the ideal choice’ – shortlist the brands/models you can audition in Delhi, research them online to give you an idea of what to expect then go have a listen.
    Keep in mind you are buying speakers to work in your room so ensure you think about positioning and mounting when making the purchase.
    Joe
    PS I see this Co. carries Anthony Gallo – we use Gallo on lots of installs, Focal Audio Systems Pvt. Ltd.
