Help With Sound
Discussion in 'Blu-ray & DVD Players & Recorders' started by SeeleyBooth, Jan 10, 2012.
  1. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    hi guys got a Pioneer BDP-140 but i cant get it bitstream correctly ive selected bitstream in Player setup but when i play a disc ie Thor it will only do DTS-5.1 no master nor no 7.1
    my amp is a onkyo TX-SR607
    i have Phoned Pioneer Tech Support who dont know what could be wrong they are going to try and replicate the problem
  2. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    have you selected in the film to do 7.1.
  3. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    yes scott i have the player wont bitstream DTS MA or True-HD of any kind ie 5.1 or 7.1
    example it takes a DTS-HD MA 5.1 tracks and makes it dts 5.1
  4. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    have you turned “BD Audio MIX Setting” to “Off”
  5. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    yes scott i have
  6. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    tried different hdmi cable,
  7. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    yes scott
  8. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,799
    player on the latest firmware.
  9. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    also yes scott it is
  10. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
    Not sure about your particular Onkyo receiver but have you checked the audio settings on it? HDMI Audio OUT should be set to OFF or it will auto downmix all audio.
  11. SeeleyBooth
    SeeleyBooth
    Apr 17, 2007
    7,278
    Staffordshire
    +474
    on what mate the player or Amp if i do it on the player it cuts all sounds altogether
  12. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
    On your amp/receiver. It's been a while but I think it's under the hardware / miscallaneous settings. "HDMI Audio out".
    It sets the Onkyo to send audio via the HDMI out, to a TV for example. However it downsamples the HD audio to do so to normal DTS etc.. so if this setting is not set to OFF, you will not get HD Audio.. regardless of if you are using the HDMI out for audio or just video.
