Help with Sony RM-MC40ELK please
Discussion in 'Headphones, Earphones & Portable Music' started by FatKnacker, Mar 4, 2005.
  1. FatKnacker
    FatKnacker
    Just got the above today after reading that it works with the HD3. My problem is that i get no backlight and nothing works on the remote. If the HD3 is off and i push a button on the remote i can hear a faint beeping noise, but nothing seems to communicate with the HD3.
    Has anyone any ideas please, or is my remote not working?
    Any help would be much appreciated.
  2. lockers
    lockers
    Jan 31, 2005
    155
    High Wycombe
    +9
    Hi - I'm sure you haven't got the 'Hold' slidder on, but just make sure its fully slid to the 'off ' position (no yellow showing). Otherwise maybe check the connection/connectore isn't dirty.
    Other than that I'm not sure what to suggest, it sounds like you might have a faulty remote. Can you return it to where you got it from and get a replacement?
  3. macha
    macha
    Hi, I have got this remote today for my HD3, and the buttons all work but the display does not work :( has anyone had this problem and resolved it?
