Help with Sony Dav-S500
Discussion in 'Home Cinema Buying & Building' started by Insane001, Mar 23, 2005.
  1. Insane001
    Insane001
    I needed to know how to get the sound from the sony DVD player to come through my T.V, so i could use the speakers to watch normal television as well as watch DVD's i would appreciate any help thanks.
  2. thewul
    thewul
    Oct 1, 2004
    275
    +15
    i think you mean you want your tv sound through your s500 speakers, so you can listen to tv programs through the amp
    in which case, if you have phono aux out on your tv you can feed this into the aux phono in on your s500
    if you do not have phono out on your tv and have a spare scart socket you can buy a scart to phono connector(make sure its an OUT they have iIN types as well) then run a phono leads to the aux in on your amp
    then just select aux on the s500 and use the system volume control
    hope this helps :)
