Help with sinking cables into a wall on my PDP435
Discussion in 'Plasma TVs Forum' started by Anderzander, Aug 20, 2005.
  1. Anderzander
    I have the plasterer coming round in a couple of weeks and I will be letting the cables into the wall.
    I have a couple of questions:
    On the PDP the system cable plugs in quite low on the set and it looks like I will be able to see where the cables come out of the wall. I won't be able to bend the cable enough so that it come out the wall higher up.
    How has anyone else managed? Is there a neat way of having the cables exit the wall?
    Next question:
    I bought the sharp 7m system cable - it has a superfluous cable - 3 bonded together where the pioneer only has 2. I am considering cutting of the 3rd cable to make it easier to fit it under the carpet and in the wall.
    Has anyone done this?
    Help :)
