Help with silent PC.
probedb
HI all,
I'm trying in vein to build a quiet PC.
I currently have a SilenX PSU which is silent, SilenX CPU cooler (can't hear a thing when the cover is on), and a single 80mm SIlenX exhaust fan.
My problem is the noise the exhaust fan makes, the fan itself is silent but there's a lot of wind noise and I have no idea how to silence it ?
ANy advice would be greatfully received.
THanks !
Paul.
ReTrO
What sort of 'hole' is the fan fixed to?
Is it a screwed on grill or punched out of the case type?
probedb
It's now an open hole and has those vibration reducing gromit fixing things.
ReTrO
Ducting then?
Can't think of anything else that might help.
probedb
Yeah I'm at a loss really, I thought it was because of the nasty grill that had been cut out of the case to start with (alu case) so I cut it out and it's a full 80mm square opening now so i'm a little confused.
I may try some ducting, cheers for the idea !
G
GRees
Another possibility is a bottleneck for the airflow somewhere inside the case - maybe around the inlets.
probedb
Yeah I think I'll have to do a bit of investigating !
65-inch LG C1 Review coming soon to AVForums
