Help with shuttle spec...
Discussion in 'Desktop & Laptop Computers Forum' started by johnny, May 1, 2003.
  1. johnny
    johnny
    Oct 6, 2000
    180
    London, UK
    I'm considering putting together a shuttle to use in a 1 bed flat to replace my widescreen TV/sony dvd/freeview box. I'm thinking I coudl use a 17TFT (such as Acer AL 712 which everyone rates) for casual freeview viewing (with a nebula pci card) and the PJ for 'event' viewing. Also be used for mp3 / dvd playing, photoshop and office apps. Gaming is not something i'm bothered about.
    Space is premium and the GF constantly complains about the 'huge black telly' and 'all the cables' so this could be a great solution.
    Can anyone tell me if what i'm proposing is likely to have any major problems?
    I'm looking at the SN41G2, Athlon XP2200+, 1gig ram, 120gig HD, Nebula Freeview card, DVD writer.
    From what i've read up on, I could still get Tivo like functionality with this set-up (i've got pipex broadband)
    Any comments / assistance appreciated.
    Johnny
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Just a few Q's first:
    What is your budget?
    Is there a size restriction on the case?
    Would you tolerate a normal sized (desktop size) case?
  3. johnny
    johnny
    Oct 6, 2000
    180
    London, UK
    well my budget is whatever it will take to do the job, without unessecary bells'n'whistles and that gives me the best bang for the buck. From my research i'm reckoning £900 or thereabouts for everything.
    I'm afraid a grey desktop / tower case is out of the question, the GF just wouldnt accept it (and its her flat unfortunately!) Reason I'm looking at shuttle is its small form factor and looks.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    The only bad things about the Shuttle systems are the lack of real upgrade potential and the noise they make. They are not the quietest PC's available. :)
    If you can afford it look at a silver/gold LMP-PC case. It'll last you much longer, looks nice and you have huge range of options to put into it.
    The Nebula card is a good choice, they may have a Sky card at some point also.
    The system should run pretty well with the spec you've set, if you don't go for onbaord sound, look at maybe an N-Force 2 based mobo. They have the option (on some of the boards) to pipe all sound as DD, and the onboard video is pretty good. Other options for video include getting a newish Radeon based card.
  5. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    My children have shuttles, with the heat pipes removed and replacement coolers from www.quietpc.com, so they are pretty quiet.
    they take up little space, and have everything on board, including SPDIF out for sound, network for broadband, built in video card. I have a Nebula card on test in my desktop at the moment, but would see no reason not to fit one in the shuttles if needed
    Picture:
    http://www.gab2001uk.com/images/shuttle.jpg
  6. Loafer316
    Loafer316
    Apr 8, 2003
    330
    Awwww cute kids gab!!.:hiya:...i'm gonna set up something like that for my little sister. :suicide:
  7. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
  8. dotBen
    dotBen
    If you are intending to use a Shuttle case, try looking at the Creative SLIX case (www.slixpc.com) which is the preferred case for the Audigy soundcard (comes with it). It is also liquid cooled rather than static heat pipes.
  9. geordie_blerk
    geordie_blerk
    Feb 16, 2002
    39
    These PCs use exactly the same cooling system as the Shuttle SN41G2 and it may be the 'preferred' case for the Audigy sound card because Creative say so, the Audigy will work in exactly the same way in the SN41G2.
    I've got a SN41G2, with a 2400+, 1 gig ram, 120 gig hd, pioneer 105 and a 9700 pro. After replacing the ICE fan and the fan in the power supply you wouldn't know it is running most of the time.
  10. dotBen
    dotBen
    Geordie,
    You're right, the shuttle does look the same OEM as the SLIXPC. I never actually looed at the shuttle until reading your post, and of course the Audigy will work fine in any case.
    My only observation is that I was able to obtain the case + audigy sound card for not much more money than just the shuttle case. My fan is also unnoticable so it's possible they use a higher grade fan
  11. ds_kerr
    ds_kerr
    Apr 24, 2002
    32
    Geordie and Gab2001,
    Would you provide more detail's on your comments regarding replacing fans/PSU's etc.
    I looked a quietpc.com and couldn't find anything that looks appropriate.
    Thanks,
    David.
  12. IanAG
    IanAG
    Dec 31, 2002
    35
    There is a great Shuttle section in the forum at Sudhian .
    They also have an FAQ which is very useful.
