help with sharp LC42XD1E
W
wiz2wiz2000
just set it up today and the volume control only has 3 settings one is mute and the other 2 are too loud.the same for all the colour and sound controls,sharp customer service is a joke can anybody help?
CDW99
Wiz,
Did you ever sort this out? I've just taken delivery of a Sharp LC42XD1ea I have exactly the same problem. It's driving me nuts!
Please help....
W
wiz2wiz2000
when i finally got through to sharp customer servce,its stuck in engineerig mode,you have to press and hold 2 buttons on the top but i cant remember which ones.you will have to ring them yourself,it takes about 2 seconds to do.good luck!!!
CDW99
Wiz,
Thanks for your reply. As Sharp tech help is closed at the weekend I had a go at pressing and holding two of the buttons on top of the TV. Eventually I got the right combination (vol minus and prog down) and I got a new menu. This showed that the TV was setup for 'Euro' rather than UK. A quick change and hey presto! everything worked.
Thanks again - you saved me a weekend of hassle...
