I'm also having serious problems with the v3.11 drivers. I've got the DigiTV card configured to be a server with the multicast checkbox ticked. The only way I could get two other client PCs on my LAN to see the server using multicasting was by reading the multicasting Howto at
www.tldp.org and issuing the following command in a command prompt (I run Win2k on all my PCs):
route add 224.0.0.0 mask 240.0.0.0 a.b.c.d
where a.b.c.d is the ip address of the PC. I had to use the above command on both the server and the clients. I didn't need to make the above route a persistent route that stays on the PC between reboots. It seems that once the clients have found the server they don't need that route anymore.
Anyway, the above is a bit academic because now that the clients can find the server they can't tune into all the available channels. Sometimes they'll find half the channels, sometimes the other half and sometimes none of them! Arrrrrrrgh!!! I'm going to revert to an earlier version of the drivers to see if one of them works.
Anyone know how to get a Nebula card working under linux?
