Help with setting this lot up?
Discussion in 'Blu-ray & DVD Players & Recorders' started by nsl100, Jul 23, 2004.
  1. nsl100
    nsl100
    Hello :hiya: , i have just bought a denon 3805 and a Panasonic DMRE100HEBS hard disk recorder. I also currentley own a old toshiba crt a pace Pace DTVA-T freeview box?
    :lease:
    Now, i am a complete novice, so could some one tell me what the best way of connecting all this up will be? :confused:
    Info i know
    TV has composite, svideo and two scarts
    Pace Box has one scart (no rf loopthrough)
    Denon has trillions of connections, red, white, green blue
    Panasonic, no idea? :mad:
    C
  2. muzza1uk
    muzza1uk
    Jun 25, 2004
    187
    +6
    Have you got some nice speakers to go with that new amp and do you plan to use the Panny DVD for music as well, I was just interested in the musical sound quality thats all. I currently use my Sony DVD-7700 and Yamaha Home Cinema amp for music and I was thinking about an upgrade and the Denon was on the shortlist.
    Muzza1 :)
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Hi nsl100, welcome to the forums.
    Connect up as follows:
    Pace Freeview Scart > Panasonic E100 AV2
    Panasonic E100 AV1 > TV EXT1
    Panasonic Optical Out > Optical Input on your Denon
    Pace Freeview Scart > Optical Input on your Denon If Pace model has Optical Out
    Notes
    You'll need to set your Pace adaptor to RGB Output (You didn't state the model but it will probably have this - see the manual). Likewise for the AV1 and AV2 connections on your Panasonic E100 (goto Functions/Setup). You'll also need to check your TV supports RGB input - it should as Toshiba have been adding inputs like this for years now.
    You Denon has got alot of connections - you don't need to use most of them though ;) The 3805 is an excellent piece of kit!
  4. nsl100
    nsl100
    Rasczak
    I really need your help now, this is driving me crazy
    i have removed the denon from the equation for now
    I have:-
    Panasonic E100 (Scart) AV1 > TV AV1
    I have set the pace box to RGB output
    I have set the panny to start on AV2
    I have set the Panny av1 output to RGB
    I have set the Panny av2 input to RGB
    I have set the AV2 Connection to Ext Link 1
    Now, when i switch my pace box on, the panny fires up, undergoes a self test and then starts to automatically record the channel...and the only way i can switch it off is by powering down the unit?...what have i done wrong? :lesson:
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    Set AV2 Connection to 'Normal'.
  6. nsl100
    nsl100
    will try that thanks
  7. nsl100
    nsl100
    Ah, thats great
    I can now view and record the same channel? how can i set it up to view another whilst recording say itv2?
  8. jem
    jem
    Sep 24, 2002
    527
    +7
    Depends on what you want to view. You would not be able to view another Freeview channel but you could watch the terrestial channels by pressing 1-5 on your TV remote.
  9. nsl100
    nsl100
    i have it sussed, just about...i think? i read somewhere that it saves the programme name form teletext? or did i dream that?
    Thanks for all your help
