help with set up
Discussion in 'Blu-ray & DVD Players & Recorders' started by PAUL RODGERS, Sep 14, 2003.
  1. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    my equipment
    L&G42PZ17 PLASMA
    DENON DVD2900
    PIONEER VSXD2011 AMP
    SKY+
    THE DVD IS CONNECTED TO THE PASMA BY COMPONENT LEADS. THE SKY BOX BY S VIDEO.BOTH SKY AND DVD ARE CONNECTED BY OPTICAL AND COXIAL TO MY AMP IS THIS THE BEST WAY TO CONNECT EVERTHING OR SHOULD I RUN EVERYTHING THROUGH MY AMP.:confused:
  2. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Paul, RGB out from Sky should be better, but if your amp can have two component inputs why not try anRGB-> component converter then you will not have to change inputs on the plasma
