Help with set up Please! DVD-TV-SKY etc
Discussion in 'Cables & Switches' started by Kier2004, May 26, 2005.
  1. Kier2004
    Kier2004
    Hopeing someone can help?
    Here is my kit
    1.Sony DAV-SB500W DVD/Surround. One RGB Scart out (none in) no component or optical but has S-video
    2. JCV LC32GA5E. One RGB Scart, Component, S-video and I assume a "generic scart" input in addition (dont think its RGB)
    3. Sky Plus.
    Need to hook the whole lot the up, What im thinking of doing is this:
    Sony DVD RGB Scart to RGB Scart input1 on TV
    Sky Plus Scart to none RGB Scart on TV
    Sound direct from sky plus to DVD
    I know it will work, but will not get scart RGB from the sky box, only the DVD? does anyone have a way that I can get the best possible set up with the limited connections I have?
    Was thinking about using the S-video from the DVD to the TV thus leaving the RGB scart input free to accept the Sky Plus feed? but dont know if S-video is as good.
    Any help would be gratefully recieved!!
    Kier
  2. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    you want rgb scart from sky to tv.
    then s-video from sony cinema kit to tv( you only need to get picture to tv and s-video will be better than standard scart)
    lastly skyplus sound to sony cinema kit.
  3. Kier2004
    Kier2004
    thanks for that, is S-video going to give me a better picture than RGB scart from the DVD player?
