Hi all! I was a lucky one and snagged a series x a little more than a year ago right after they first dropped. I love it, but not so much the controllers they come with.
About a month after I got it, the B button on the controller it came with started getting "sloppy" if thats the correct term. It did function, but you couldnt feel it, if that makes sense. Microsoft warrentied it. 6 months later the new controller got stick drift that I couldnt adjust out of it. Since it was out of warrenty I tore it apart, cleaned it, no difference. (Yes it was updated, yes I put new batteries in it.) So i spent $70 on a new one. Its currently 5 months old, and the RB, and A button are both "sloppy."
Am I the only one having such serious issues with these controllers? I consider myself a somewhat serious gamer, (I play alot of fast paced COD match games,) but by no means serious enough to spend $200 on an elite 2. I do tend to play with a pretty heavy hand. I blame that on years of playing with worn out controllers in my childhood, where you actually DID have to press buttons harder for them to work. I still dont think i should have worn out 3 controllers in 14 months...
If anyone else is having my issue, what controller would you recomend? Im on track to spend as much on controllers as I did the console...
