Johnnybravo87
I am after a bit of help, i currently have a denon 2309 7.1 avr which is working pretty well and i am happy with.
I am currently using a budget Eltax jupiter speaker system which i have had for about 8 years. (2x tower, 1x center, 2x small bookshelf). Teamed up with a B&W AS2 subwoofer
I want to get better sound and on a very tight budget and have currently come across a set of 4 Mordaunt Short Avant MS902 bookshelf speakers for £70.00
Can anyone please give me an idea of the quality of these speakers and if they are any good with denon? Also would i notice an improvement for movies against the budget Eltax set i have been using?
Any help would be appreciated as well as any other pointers and tips.
Thankyou
password1
I had the previous model Ms902. They lack bass, but not an issue as you have a sub, clear vocals. Imaging not great.
I would avoid the avant models because they have the common problem of the star shaped imprint on the cones over time.
Johnnybravo87
Hi there thankyou for responding i very much appreciate it.
I have read a lot of good reviews about these speakers but not from anyone i have communicated with.
I have heard the star shape is just an aesthetic thing and will not affect the sound quality or performance which i dont mind so much about if its correct.
The seller has now included the 905i centre speaker to match it.
Do you think i will gain better sound detail with movies etc over the buget Eltax brand i am currently using?
Any help or any other feedback about these speakers or the mordaunt short brand is really needed and appreciated.
password1
Personally I would avoid unless really cheap or free. The star shaped imprint is a design flaw.. They're not meant to develop the imprint on the cone over time.
Yes should be better than the cheap and cheerful Eltax
