Help with Scart
Discussion in 'Digital TV & Video Players & Recorders' started by Pip_UK, Jan 14, 2002.
Tags:
  1. Pip_UK
    Pip_UK
    CALLING ALL SCART GEEKS :p
    No seriously .... I plan to use my Cable NTL box with my new projector. I am moving in a few weeks and was fortunate enough to have a nice builder that has run component and s-video leads for me acroos the walls and ceiling before he put the walls up. I purchased the leads and they are good quality.
    I am having two cable boxes. One for recording through the JVC HD and SVHS recorder and the other direct to the projector through the amp (switiching).
    I contacted Pace who supply the cable boxes to NTL as they only have scart output.
    Pace sent these spcs of the two scarts ...
    TV SCART VCR SCART
    1 Right audio output ± 6dB Right audio output ± 6dB
    2 Right audio input Right audio input
    3 Left audio output ± 6dB Left audio output ± 6dB
    4 Audio ground Audio ground
    5 Blue ground Blue ground
    6 Left audio input Left audio input
    7 Blue output Blue input
    8 0-2.5 volt: Off ( High if a connected VCR is in 4.5 – 7.5 volt: 16:9 Playback control
    playback mode) 4.5 – 7.5 volt: On (SAT AV (input from VCR only) 9 – 12 volt:
    and 16:9 control to TV) 9 – 12 volt: On ( SAT 4:3 playback control ( input from
    AV and 4:3 control to TV) VCR) or output for aux record mode
    9 Green ground Green ground
    10 N/C N/C
    11 Green output Green input
    12 N/C N/C
    13 Red ground Red ground
    14 N/C N/C
    15 Red output or chrominance output Red input or chrominance input/output
    16 0 volt: Off (CVBS to TV) (High if VCR is in 0 volt: Off
    RGB or OSG mode, 1 –3 volt: On (RGB to TV) 1 – 3 volt: On (RGB to TV)
    Blanking (RGB overlaid to CVBS) n/a
    17 Composite video output ground Composite video output ground
    18 Composite video input ground Composite video input ground
    19 Composite video / Y output Composite video / Y output
    Low = -10%, High = +10% Low = -10%, High = +10%
    20 Composite video input Composite video input
    21 Ground Ground
    Question is whats the best connections for both cable boxes (this is all gobblydeygook to me :( )
    Any advise would be gratefully appreciated
    Pip
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Pip,
    As far as I know the cable box will output rgb on the scart connector. You can feed that directly to the projector if your projector has a scart input. If it doesn't, the best thing to do is to get a rgb to s-video convertors (from www.rgbtosvideo.) and run that to the amplifier. You'll have to get a second one to get the best recordings on the s-video vcr anyway.
    brian
