help with scart adapter please...
Discussion in 'Cables & Switches' started by owen021173, May 2, 2007.
  1. owen021173
    owen021173
    Apr 5, 2007
    4,716
    scarborough
    +339
    i have a tv with only 2 scarts. av1 is my sky connection but for av2 i have a vcr/dvd player and playstation 2 to connect so i bought a 3 way scart adapter to plug themall in using the av2 scart.
    i have sound through vcr and dvd (have'nt tested ps2 ) but no picture????
    can anyone tell me why ???
    thanks
  2. berkeley384
    berkeley384
    Nov 28, 2006
    1,280
    +222
    Hello, have you considered that your 3 way scart adaptor is broken , what happens if you plug directly in to AV2
    Out of interest on a lot of TV sets only AV1 is an RGB input offering better picture quality, have you considered plugging your DVD scart into the sky box rather than the T.V to free up another scart lead?
    Do you have a composite video In on the TV? If you do then you could use that for the PS2 and the AV2 for the VCR - No scart socket required ... just an idea
  3. owen021173
    owen021173
    Apr 5, 2007
    4,716
    scarborough
    +339
    thanks for that.
    tbh i think its the scart splitter. it is a cheapo one off ebay :rolleyes: and yes it serves me right!
    i think a decent quality splitter is the order of the day dont you!
    thanks again
  4. blue73
    blue73
    May 30, 2003
    113
    Manchester, UK
    I know it's a bit of messing about, but have You tried shutting down Your TV and plugging in all Your devices seperatley to AV1. Then doing the same with AV2.
    Purely to elliminate the ports on the TV.
    See some TVs won't switch AV cons unless they are turned off.. And then turned back on again..
    It may have nothing to do with the "splitter". It might just be the TV being subborn..
    Just out of interest, What Model TV, Cable/Sat/Freeview/DVD/Games Console set-up do You Have and what cables are You using. Also what is the name/model of the "splitter" You are using?...
