P
poinsy
I have probably missed this in the manual but, is there a way to switch to TV, then back to a DVD without it restarting the DVD from the beginning ? I can do this if I use the separate TV remote by using the button to switch the AV input, but would like to do this from the Panny remote if poss.
Also, can the cd carousel be rotated whilst it is open ? I though that I had done this once, but cannot seem to do it anymore.
And another thing... Can the automatic closing of the cd-carousel be turned off ? Often, it closes before you have exchanged DVDs, or even worse, whilst the new one is not quite in place - you then get the most unpleasant screaching sound as it tries to play it
Paul
Paul
