Question help with sbl and sbr
Discussion in 'AV Receivers & Amplifiers' started by michelleyx, May 3, 2017.
Tags:
  1. michelleyx
    michelleyx
    May 3, 2017
    uk
    can anybody help I've just bought a pioneer htp-070 and have set it all up but when I did a speager test SBL and SBR wasentry working now I'm not sure why as ive got my speakers all set up what do I need to do get more speaker wire and add them to the back plz help z
  2. Rambles
    Rambles
    Jul 14, 2004
    10,386
    167
    UK
    +2,121
    Are the surround right and left speakers connected to the amp with speaker wire? If not, then that is necessary.
  3. dante01
    dante01
    Mar 5, 2009
    46,432
    +11,176
    The Pioneer HTP-070 is only a 5.1 system so wouldn't accommodate (or need) surround back speakers.\
    Surround back speakers are only used within 7.1 setups.
    Are all the supplued speakers that came with the setup connected to the receiver and have you followed the setup instructions given in the manual?
  4. Rambles
    Rambles
    Jul 14, 2004
    10,386
    167
    UK
    +2,121
    But would the speaker test then try and play tones to surround back left and right? I was guessing that the OP meant surround speakers, rather than surround back.
  5. dante01
    dante01
    Mar 5, 2009
    46,432
    +11,176
    Apparently the AV receiver that comes with the system (the VSX321) is only a 5.1 receiver so it neither has back speaker terminals nor would it output a test tone associated with back speakers.
  6. michelleyx
    michelleyx
    May 3, 2017
    uk
    I'm not sure bit they r all connected withave speaker wire and when I did the test all other speakers were working and when sbl and sbr was display I didn't here nuttin
  7. michelleyx
    michelleyx
    May 3, 2017
    uk
  8. dante01
    dante01
    Mar 5, 2009
    46,432
    +11,176
    and you have 5 speakers and the sub connected to the receiver? If so then I'd suggest you ignore the SBR and SBL channels because the receiver doesn't have the ability to drive back speakers so you cannot add them.
  9. Rambles
    Rambles
    Jul 14, 2004
    10,386
    167
    UK
    +2,121
    Okay. So something isn't working. It might be that it isn't configured correctly, or that something is broken. Did you buy it new or second hand?
    Some troubleshooting steps would be to try connecting the surround right and left speakers to the fron right and left amp outputs and trying the test tones again. This way you can eliminate whether it is the speakers that are the problem or the amp.
  10. michelleyx
    michelleyx
    May 3, 2017
    uk
    Yes on the back the terminal I have is front left front right sub woofer and surround but on the display it's doneasy a test and showing sbl and sbr
  11. michelleyx
    michelleyx
    May 3, 2017
    uk
  12. michelleyx
    michelleyx
    May 3, 2017
    uk
    Ok thanks will try this now xx
  13. Rambles
    Rambles
    Jul 14, 2004
    10,386
    167
    UK
    +2,121
    Do you get test tones from five speakers (front, left centre, surround right and surround left)?
  14. brantuk
    brantuk
    Jul 12, 2016
    355
    3
    44
    Leicester
    +225
