Help With Sanyo Z3
Discussion in 'Projectors, Screens & Video Processors' started by activeuk, Feb 24, 2005.
  1. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    just got my pj set up i need help please i have set my pc to 1280x720
    but when i press screen i only get the opions of natural wide2 and full the pic is just to big for my screen any help please if i go to 800x600 i get all the opions
  2. Supersonic
    Supersonic
    Jan 5, 2005
    1,162
    Surrey
    +219
    Not sure what you mean by 'too big'. I set my PC (Radeon 9800 Pro) desktop to 1280x720, at 60Hz, and the picture is exactly right for the pj - no scrolling the desktop or anything like that. I get the signal into the Z3 via a DVI-HDMI cable, going into the HDMI port on the pj. I don't use the 'force 720p' or anything like that. The setting I use for inputs is 'Auto', otherwise I just set it to HDMI.
    How is your pj connected to the PC?
  3. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    hdmi
    i put the pj i min zoom and its to big for the pj screen
  4. matisamd
    matisamd
    Feb 24, 2005
    34
    cant you just move the pj abit closer to the screen
  5. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    the pj is fixed to the wall i do not understand why i can only pick the 2 options of natural wide2 and full
  6. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    These options refer to the shape not the size of the image. If you want a smaller image and the zoom is at it's min, your only options are to move the pj closer to the wall with the screen or move the wall with the screen closer to the projector (the latter probably not being an option ;) ).
    It sounds to me that you may have bought a pj that does not suit your room. If you bought it from a retailer that will allow a return within seven days you may want to consider this.
