help with Samsung LE40N87BD.
Discussion in 'Samsung TVs Forum' started by msan, Jun 16, 2008.
Tags:
  1. msan
    msan
    Jun 16, 2008
    2
    Hallo, I'm in Italy, so sorry for my bad english, and I've bought a LE40N87BD a few months ago.
    In' using an external decoder, I-can 3800 Hd, to see european championships in HD.
    The resolution displayed i 1080i.
    I've noticed the so called effect motion blur on some fast movies and especially in titles tail when they run fast.
    With my old crt televisione I never noticed that.
    Is a problem of the n87 model?
    Can I upgrade my firmware to resolve it?
    Thank you.
  2. KUBBY
    KUBBY
    Nov 6, 2006
    3,086
    Leicestershire
    +664
    Have a look in the Menus.If Motion Plus is switched on,turn it off.
    Good Luck
    KH
  3. msan
    msan
    Jun 16, 2008
    2
    all the filter are switched off, have you the same model and without any motion blur?
    is a problem of my tv?
