HELP!! with Samsung LE19R86BD!!
Discussion in 'Samsung TVs Forum' started by J.A.C.K., Jun 15, 2008.
Tags:
  1. J.A.C.K.
    J.A.C.K.
    Jun 15, 2008
    I am having trouble getting the Picture-In-Picture to work. When i go to activate it on 'Setup' in the menu, i cannot select it. I also read in the manual that pressing the 'PIP' button on the remote several times will activate it, however this doesn't work either. A message comes up on the screen saying 'Not Available'
    Any help would really be appreciated,
    Thanks.:thumbsup:
  2. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    pip will only work with certain inputs. you should find a table in the manual showing what you can use it with. eg pc and tv. you cant use pip to give you tv and tv.
