help with samsung 55 inch screen
lost tech
JayCee
Have you done what the message on screen is telling you?
Do you have a known working aerial plugged in?
What is the TV's model no?
lost tech
I have done what the message states. As you can see in the picture the upper left corner of the screen is white and middle section a little darker. I don't think its the LED because of the white picture, however, I could be wrong. I connected to the cable and the picture comes out, but not sharp and clear.
This is a Samsung UN55EH6000FXZA. Version CH01
Its seems like its not lighting up the top one third of the picture on the left side.
Thank you for responding
JayCee
You posted the pics on their own with no accompanying text stating what the problem was so I assumed it was no signal.
Post a pic with a source connected and a picture showing, that way we can get a clearer view of the symptoms, a screen full of snow isn’t the best thing to judge it on.
lost tech
JayCee, attached are 2 pics. Thanks for your help
lost tech
Thanks for helping. Set is about 5-6 years old, just out of warranty. Funny thing was that it ran intermittently for about week, then it crapped out. I don't know. I see only 3 boards, looks like, power, "motherboard?" and AV type board. Motherboard looks like glued or screwed down from opposite side of mount so can't remove to check connections. I also do't know how to take off front screen to check if all LEDs are firing, also bottom portion connections that tie to motherboard and rest of speakers(?)
