Help With RX-V461 amp??
Discussion in 'AV Receivers & Amplifiers' started by ellieoxlade, Jan 16, 2008.
  1. ellieoxlade
    ellieoxlade
    Can anyone help ??? trying to set up rx-v461 amp to my toshiba xf355db tv and upscaling dvd player using hdmi leads havent a clue what im doing which leads go where ???????
  2. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    So you need a HDMI lead from the DVD player to the Amp and then another one from Amp to TV. You will probably also need an optical cable from DVD player to Amp.
    Next step is to set the amp up to understand that the DVD mode/function should take video over hdmi and sound over optical. I have no idea about how to do this on a Yamaha, maybe the manual or someone else can help here.
