Help with RGB , Philips 28' widescreen and Sky Digibox
Discussion in 'Sky Digital TV Forum' started by gazzfoth, Aug 12, 2004.
  1. gazzfoth
    gazzfoth
    May 7, 2003
    32
    Just recieved a Philips 28' Super Flat Widescreen TV (i know it not flatscreen) and just set it up. It has 2 scart sockets at the back, an RGB socket and svhs socket. Bit annoyed about this as i didnt know it only had 1 rgb socket. I plugged my digibox into rgb socket and pic is ok, not brill. Went into sky picture setup and changed Video Output option to RGB instead of PAL, and the picture went all green and yellow. changed back to pal and the pic was colourful, but quite fuzzy and crap. Now i have my PS2 plugged into the svhs socket, which was an ok pic again but not brill. Swopped it round with sky so the PS2 is now in RGB, and the pic is brill. Why is it that when i plug my digibox into the rgb scart and select rgb output in sky settings it goes all dull and crap? Please help.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Since you have confirmed the TV scart socket and scart cable are ok then it's reasonable to assume that the RGB output of the digibox is faulty, Panasonic?
