help with RGB input on AE300 needed
Discussion in 'Projectors, Screens & Video Processors' started by sapperjohn, Nov 11, 2003.
  1. sapperjohn
    sapperjohn
    Jul 23, 2003
    188
    2
    Devon
    +7
    Now I had this really good idea to use my existing component cables and a composite cable to deliver Sky+ RGB to my AE300 to save me running new cables through ceiling and taking up carpets and floor boards (yet again).
    The idea seemed so simple and fool proof. Buy 2 RGB+composite sync phono to scart adaptors from Lektropacks. http://www.lektropacks.co.uk/dept.asp?dept_id=208
    Plug one into the AE300 and one into the sky+ box, swap cables across from DVD player and from component input on the AE 300 and hey presto RGB from the Sky+.
    Result.. Nothing. absolutely nothing
    So what Am I doing wrong.
    Checked to make sure Sky+ box is outputting RGB.
    Selected AV1 Auto on the projector
    Checked all cables
    Tried all combinations of input/output switches on the adaptors
    I`m either missing the obvious or completely deluding myself.
    Anyone help
    Sapperjohn
